Bonnet Open
In your case it'll be the switch as others have suggested. I kept getting the 'bonnet open' red light warning when driving along. When I inspected the bonnet it was actually open, only a little, but it was open. I released the bonnet and found that it would not shut without really slamming it down. When it eventually engaged it would ping slightly open again once I was driving. I greased up the latches and that solved the problem. The latches seem to seize up and will eventually start to release the bonnet when driving or going over bumps.
I hope you get it sorted.
Thanks,
Chris
Thanks,
Chris
The following 2 users liked this post by BDuncan:
JX350 (07-25-2020),
Partick the Cat (07-23-2020)
regards Stephen
ignore sig - i cant work out where to edit
