boot release
Old 06-18-2017 | 01:06 PM
romroc's Avatar
Default boot release
Could use a pictorial on boot release servo, electrical testing. Not even urgent as the key opens trunk. That and the rear proximity system mostly emits a constant beep in reverse. Utterly smitten w this Jag.,the first after 15 years. In a class of uno, break out the cliqous as necessary.
Old 06-18-2017 | 06:31 PM
meirion1's Avatar
If you are sure it is the boot release lock that's at fault just replace it.
I had constant beep, it was two faulty sensors. Drop rear bumper and
with system running replace until noise stops.
PS Love Cliqqers too!
Old 06-18-2017 | 09:01 PM
romroc's Avatar
Sometimes the backup works correctly. Want to check continuity before replacement. How do you get to it?
Thanks!
Old 06-19-2017 | 06:32 PM
meirion1's Avatar
Old 06-19-2017 | 11:17 PM
romroc's Avatar
Originally Posted by meirion1
Thanks. Sometimes she works, mostly just drones.
Old 06-20-2017 | 07:58 PM
meirion1's Avatar
drones.???????
Could be a problem with the sounder, it's on the rear parcel shelf but
can be accessed for testing from rear light wiring.
Old 06-20-2017 | 10:35 PM
romroc's Avatar
drones.???????
Thanks. Gonna try and pull fuse f32. When this car is registered, it needs some actual use!
