Bottom hose collapses,
I was checking things out under the hood last night,, its a 2007 x350 xj8, noticed the bottom hose was collapsed . the engine was cold, the coolant level in the expansion tank was raised slightly,
The expansion tank, thermostat and housing were replaced just under three years ago,
Took car for a run , does not overheat and hose felt ok,
This morning the hose looks ok but when i compress it it feels empty,,
does anyone have any idea what the problem is?
regards Dave
2007 xj8,
regards Dave
2007 xj8,
Hoses are made of a better grade rubber, softer to the touch when squeezed, compared to the regular type of coolant hoses, which are much stiffer. Whats the milage on them?After 100,000 miles you might want to replace them anytime they are removed, as when the water pump, or any other coolant part is replaced.
I had a similar issue on my daughter's BMW X3. I went through all of the above. In the end I bought a new hose and replaced it. Issue resolved.
I would do the same process mentioned by others, but hoses do age and do get soft. From my research a slight negative vacuum is in the system once the engine cools. Heat expands - cool contracts.
