Brake Booster Solenoid codes
Old 05-03-2021 | 08:55 PM
pragmatic's Avatar
Default Brake Booster Solenoid codes
In another thread I explained how my brake booster was causing lean operation. Changing the brake booster fixed that problem (long term fuel trims have dropped from 25 to less than 4) but now I have lost Dynamic Stability Control. Error codes are as follows:
C1285 - Booster Solenoid Output
C1287 - Booster pedal force switch circuit failure
B2736 - Pedal travel sensor failure
At first I thought it was the junkyard booster I installed so I removed it and installed a rebuilt unit from Rock auto, same codes.
So I must have damaged wiring or connected something wrong during the booster install. Does anyone else have experience with these codes?
pragmatic
05-03-2021 03:16 PM
mark1210
11-02-2017 12:41 AM
mark1210
07-25-2017 11:09 AM
al_roethlisberger
03-31-2016 04:44 PM
Myjag2sexy
07-01-2013 10:02 AM
Quick Reply: Brake Booster Solenoid codes
