Brake Job?
Brake Job?
Hey guys.
I have a 04 xj8 that is in need of a brake job. Priority #1 is no more brake dust! So I'm guessing I need ceramics? I would like to spend between 4-$500 for pads all around as well as rotors. Is this possible? I would like something other than OEM so what do you guys recommend? Any good websites? Thank you everybody!
EBC Redstuff pads. That's what I will switch to when it is time. Lot's of good info here regarding them. Probably going to spend around $250 give or take a bit for front and rear pads. There are cheaper pads out there (like Napa for $50), but you get what you pay for. I've seen rotors anywhere from $50-$80 or more each.
I put ceramics on my 04 XJ8.
Pads were Akebono from Rock Auto:
EUR1065
EUR806
Discs were premium from R1 Concepts (Posi-Quiet ceramic pads also available. I used them on my XKR).
Posi-Quiet ceramic pads:
Front - 105.09330
Rear - 105.09440
Premium discs:
Front - POE.61077
Rear - POE.61062
EUR1065
EUR806
Front - 105.09330
Rear - 105.09440
Premium discs:
Front - POE.61077
Rear - POE.61062
Jaguar has not had any drilled rotors that I have ever seen from the factory. And the only stock drilled rotors I have ever had on a sedan was the Benz. From what I understand, it is not necessary since these cars were never designed to be race cars where drilling helps with the additional build up of heat from constant braking.
I'll admit cosmetically they look nicer than stock, but in the end unnecessary.
The cheapest quote I got was around 1100 for all corners - rip off. I have just finished it myself - The car is a hell to bleed - but it worked. I have not driven far enough to be able to give a review on the parts I used - next coming day I can give more. What I can say is that advanced autopart has the special brake tool and you just put a deposit down, no real pay Without the tool you will no make the rear brakes
It is a bitch to bleed
I did the brakes myself - having only done my wife's dodge caravan beforehand.
I followed the instructions on various threads here. the brakes are well made and were easier to work on than the Dodge.
I used aftermarket parts from Autovalue (Pilenga rotors and pads - there's not so much available in Canada).
The brakes work great - and there's much less dust.
Total was less than $600Can (about $800USD these days not really - about $630USD)
Edited to add - since I was doing that I bled the brakes using a jam jar and some hose from Autovalue. That cost 20 bucks or so. The jam jar was free!
I did the brakes with Pagid pads from BAP/GEON. They stop quite a bit better than ceramics and have no more dust ( I really dislike ceramics for the lower braking performance they have, not good enough for a high perf car for my tastes). Pagid is one of the oldest pad co's out there and the quality is very high. I have found that generally, BAP is the best parts source I work with for aftermarket parts. The standard brakes on the car are nothing fancy to work with, the fronts are assymetrical two-piston which is uprated from most cars though. The rears require a rotating piston retractor which is available from Harbor freight in a kit. Get an Alldata.com subscription or similar if you need instructions. I also suggest replacing the brake fluid if it's never been done. I recommend a Motive Products pressure bleeder to make the job easy and one-person.
What experience have you and with ceramics and brands?
People like the ceramics due to their low dust, but dust is directly related to friction, low dust-low friction! The balance of wear to friction is also an issue. Some pads are so hard and high friction they wear the rotors out too fast, so it is a matter of balance on a road car, racers replace the brakes often, so wear and dust are not an issue. The Pagid pads have a better balance of friction to dust than the ceramics I have used, all by Akebono on my 96 XJ6. The Brembos I have on the XKR are low dust and stop well, they are original pads so I assume they are Brembo pads.
Dickie_L_J_O
09-13-2015 07:44 AM
