brake rotors and pads
I have a 2006 black on black XJ8. I am looking to redo my brakes and am wondering if anyone out there has used aftermarket equipment. The OEM gear is 200-300 per wheel vs some more reasonably priced Zimmerman rotors and akebono ceramic pads that run ~ 100 wheel
Pierre
Pierre
I used Centric premium rear brake rotors and posi-quiet semi-metallic pads kit part # 90920502 and front pads part number 10412402, I didn't get the front rotors because the existing ones were good. All from Rock Auto at a cost of $189.56. So far so good.
I just had a full set of E-line crossed-drilled and slotted rotors installed with their ceramic brake pads (ordered from R1 Concepts via Amazon). $254 delivered. I am looking forward to saying goodbye to the black dust on my wheels. With install, total cost was a bit less $500. (Had my upper front control arms replaced at the same time, as the ball joints were loose.)
Sammy Walton
09-19-2016 07:08 AM
