Brake Squeaking
Brake Squeaking
So thanks in advance for listening to this novice question. After replacing several bushes in the front suspension I was reattaching the caliper (I had initially considered replacing the knuckle but decided against it.) when I picked it up I noticed a little metal clip fell out. There are four total holding each of the pads in place. The one that fell out looks broken but I put it back together and drove slowly around the block. The noises from the front suspension seem to be gone (hurray) but there is a constant squeal now from he front left brake. I assume this clip holds the brake pad off of the rotor when your not braking but am I right? I should have the new one in this afternoon or tomorrow but I wanted to make sure I didn't do other damage.
Clips
Don B (07-01-2014)
Received 12,942 Likes
...when I picked it up I noticed a little metal clip fell out. There are four total holding each of the pads in place. The one that fell out looks broken but I put it back together and drove slowly around the block. The noises from the front suspension seem to be gone (hurray) but there is a constant squeal now from he front left brake. I assume this clip holds the brake pad off of the rotor when your not braking but am I right? I should have the new one in this afternoon or tomorrow but I wanted to make sure I didn't do other damage.
Hi Lance,
I'm attaching the diagram of the front brake components from the Electronic Parts Catalog (EPC), which you can download from the X350 'HOW TO' Quick Links thread on the home page of this X350 forum. The diagram doesn't seem to show any clips available as separate parts, so I think Ed is right that the part you found may either have broken off of a pad, or may need to be clipped onto the pad in some way. Our '04 has the Brembo brakes, which are a little different, so I can't visualize the part you are describing. Let us know what you figure out.
Cheers,
Don
xjrjag
09-24-2015 10:08 PM
