Brakes "grab"
So my car runs and drives quite good but there are a few things I will tackle to make it perfect. One thing that I haven't figured out yet is my brakes that are "grabby". Background: 06 XJR 79K km (~50K miles)
OK so since grabby isn't a word I'll do my best to explain it. If anyone has any ideas on why this is happening and how to fix it let me know.
When I press the brake pedal, if I press it very slowly and gently (still safely) it stops what I would say normally, smoothly, albeit slightly slower than normal.
If I press the brakes either hard/quick or even at a medium/normal rate the brakes have a harsh grab at first. It's almost as if there is a boost of brake pressure initially or a caliper or two that are grabbing momentarily. After the initial grab they seem to work fine.
It's very noticeable and I'm sure not normal, I've driven dozens if not a hundred+ vehicles in my life and not experienced this in any other car.
I asked the Jag dealer for service history and it was brutal trying to get information from them, but I got them to admit that the brake fluid was never flushed.
I'm not sure if a brake fluid flush would help but I was thinking that could be a next step to rule out a fluid/air problem. Usually an air problem would give a spongy brake pedal so I really doubt it's fluid related.
I don't want to randomly replace parts. I'd like to find a way to properly diagnose the issue without having to spend $2,000
![Icon Razz](https://www.jaguarforums.com/forum/images/smilies/icon_razz.gif)
These cars have something called " Emergency Brake Assist". It is supposed to detect emergency braking and "assist" the driver to brake the car. So there may be a fault somewhere in the system, and it is applying the logic incorrectly.
X350 Specs - Press release 21st December 2002
I don't want to randomly replace parts. I'd like to find a way to properly diagnose the issue without having to spend $2,000![Icon Razz](https://www.jaguarforums.com/forum/images/smilies/icon_razz.gif)
It happens at any speed, and it happens whether I have traction control on or off, cruise on or off (I can feel the grab if ACC slows me too). My engine runs a touch rough at cold startup but I have new spark plugs to install.
I'd hate to take it to the dealer if there are some initial diagnostics I can do first to help narrow things down. I have above average knowledge on cars and how they work but I am a Jag newbie.
Anyone have access to the factory service manual for this braking system?
So I did some more searching in the forum here and one guy had brake issues that was diminished after doing a hard reset on the battery (his words). After a little while his brake power went strange again.
So I think I will do a "hard reset on the battery". How long do I need to leave the battery disconnected for on this car? And, is there anything I need to know after I reconnect the battery for any of the system?
It appears JTIS only works on Windows?? I only have Mac computers.
I can tell you this isn't normal. Now that I know just a tiny bit more from searches here and other places, my hunch is that a sensor such as an accelerometer may be faulty or otherwise be causing some of the issue. You see, if I slow down really gently it's OK but if it's normal or hard braking, there feels like that big boost of brake pressure (surge?) for like a 1/2 second. So I am suspecting something in the EBA system is the cause. If I could just find a good technical explanation of the entire system I could maybe even disconnect a sensor and see if that will affect things. I don't need a tech to tell me if what I'm experiencing is normal, it definitely isn't.
I have an Actron OBD-II scanner CP9580 @ http://amzn.to/2cNFIER but I doubt it's capable of reading advanced Jag stuff. I used it just to read for DTCs when I bought the car, I haven't tried any advanced stuff yet.
Well this is interesting... so I took the Jag out for lunch and to run an errand. I don't drive it every day for a # of reasons. But...
After pulling out of the driveway I decided to take it out of sport mode. So I drove around in regular mode and the brake grab issue was at least 50% less pronounced. In other words it's nearly normal! I couldn't believe it.
So, I put it back in sport mode and did a bit more driving. I didn't drive it a ton but I can say that I can brake like a normal car now when either braking lightly or normally (medium pressure). I did have to step on the brakes hard one time because a car was coming and I could feel the harsh grabbing. Overall it's much better, more bearable for sure. It still grabs hard when you jam on the brakes quickly but normal and light brake feel is MUCH improved.
I'm going to continue to monitor the situation but that is really odd. I wonder if the brakes are changed somewhat between sport and regular mode? I have driven in sport mode 99.9% of the time since getting the Jag due to how it shifts.
I didn't reset the battery, I didn't do anything other than take it out of sport mode after leaving the driveway...
Interesting development, I'll keep you posted.
Received 9,007 Likes
DGorvetzian
09-15-2016 05:12 AM
