brakes, mileage, rear wear and stability control
My 2008 XJR is at 17,500 miles. Dealer says rear brakes have 2 mm left, front are OK.
1. This seems to me to be minimal pad life. Most of my driving is suburban, spirited when I can. Although the car hasn't been out in the rain or snow that often the stability control is engaged frequently on those occasions.
2. I may be hallucinating but on many occasions I have turned off stability control and the throttle seems more responsive and the shift points changed. I always drive in sport mode. Anyone have any experiences?
This is a problem common to cars that use electronics to control the rear drive and stop wheels spinning. The old way was a limited slip diff, but now the system brakes the wheel that slips under traction. Essentially, the car is using the rear brakes as well as you, but only you use the front brakes,
KarimPA
09-12-2015 08:15 AM
