Broken off col packs
I have tried those, I cut groves in a spark plug socket,I have tried coat hangers, picks etc. Nothing seams to make half of the coil packs come out.If it was just a rubber boot I think it would have come out but this is half the length of the coil pack.I have yet to have a response advising if the valve cover will come off with out them being removed? I am afraid of damaging the plastic valve cover.Seems like an easy question if you have ever removed one so I guess I will just have to try for myself and let everyone know the answer.Any ideas would be greatly appreciated
I have tried needle nose, a spark plug socket with groves cut in it to tear up the rest of the coil pack.I have tried picks etc.If it was just a rubber boot that would be no problem, but it is half of the coil pack! In two cylinders.I have tried a hamer and a punch to break it up but I can only see the center of the spark plug so far, after 2days I am at my wits end on removing them so I can replace the spark plugs.
I was thinking that if the valve cover can be removed without taking out the spark plugs,, maybe That would give me enough access to remove the rest of the coil packs.But I have yet to find any info.Every post about valve cover removal doesn't mentIon the spark plugs having to be removed. I guess I will have to answer this question myself by tiring to remove it.Wish me luck!
Doyle (08-07-2017)
Doyle (08-08-2017)
Successful!
Well after 3 1/2 days I finally have some success. I was able to take a 5/8 hole saw bit on a drill and a chisel, hamer and a lot of cursing.This car has been sitting since October 2015, first I replaced the old gas, scanned it after replacing the plugs and two coil packs it still runs a little rough but before I could drive it, the thermostat housing started to leak, great.So I have placed another order for parts and will be giving it another in a couple of weeks. Thanks for all the encouragement and knowledge, you all a e a blessing ! Thank you again everyone!
aholbro1
05-07-2019 10:16 PM
mrobinson
10-10-2014 09:18 AM
H20boy
05-03-2012 09:51 PM
Dirkman
06-07-2011 09:00 PM
