brushless aux water pump option
Old 02-04-2019 | 01:54 PM
megacattin's Avatar
Default brushless aux water pump option
Good day,
My stock aux water pump is worn out doesnt work anymore.
Looks like 01 durango's used a sort of similar aux water pump along with other vehicles.
I went and found this brushless motor, I'll be installing it on my 04 xj8.
Wish me luck 44 bucks shipped.. We will see how this goes hah!
https://www.ebay.com/itm/162820874177
Old 02-05-2019 | 05:01 AM
EsRay's Avatar
Old 02-05-2019 | 07:11 AM
megacattin's Avatar
Right on paper it says it won’t fit, the mount is different but I’m assuming the hose size is the same. I’ve built a couple of cars in the past and have done custom work so that is not scaring me off.
anyway will keep you all posted.
Old 02-05-2019 | 08:13 AM
EsRay's Avatar
I am always interested in learning something new, how do you tell that your Auxiliary Pump is failing; what are the symptoms, please?
Old 02-06-2019 | 05:26 PM
Wingrider's Avatar
Lack of heat, is a big one, but not the only one.
The 07 had no heat at all, when i went to look at it, back in Dec of 17.
They put a new one in, giving me plenty of heat.
It helped the 04 a lot less, but it did help some.
Don B (02-06-2019)
Old 03-18-2019 | 02:48 PM
megacattin's Avatar
This pump does work.
I cut off and soldered in the new wiring for it as the harness is different.
Very simple.
Worst part was going to Ace Hardware and getting a brass reducer as the fitting for the hose is slightly different compared to the oem hose.
I then got 5/8" hose from Advance auto (size of this pump's outlet and inlet) and worm screw hose clamped it up. All worked.
Mounting is not going to fit like it used to on the radiator, but I used a zip tie or 2 and all is good.
The brushless pump *should* last longer than the brushed motor. My oem motor was dead.
Hope this helps, I will try and remember to get the exact brass fitting I bought tonight so you all can see.
The following 3 users liked this post by megacattin:
Datsports (03-19-2019), Don B (03-19-2019), wwr (03-20-2019)
Old 03-18-2019 | 02:59 PM
Wingrider's Avatar
Good find, for a nice adaptation, to make things work for you.
Old 03-20-2019 | 01:05 PM
megacattin's Avatar
Here is the adapter plug that I got in a pinch from ACE hardware. You will need 2 of these (one for inlet one for outlet) and 5/8" heater hose if I remember correct. Makes the transition perfectly.
wwr (03-20-2019)
Simran Singh Randhawa
12-06-2016 11:12 AM
bamforp
08-05-2015 11:40 AM
vdpnyc
06-25-2015 09:52 AM
TallXJDriver
10-15-2013 06:20 PM
Anticitizen
19
05-29-2013 11:14 AM
Quick Reply: brushless aux water pump option
