Bypass Air suspension warning system.
I am considering having an after market coil over system installed to replace the air ride on my 2006 XJ8L Jaguar. .. How do i avoid getting an error message on the dash warning system? How can the system be bypassed, so that it thinks everything is working properly?
Previous owner did the same.
I was behind the back seat to feed my back up camera wire to the trunk. All the plugs are disconnected from the module.
No warnings whatsoever since I owned the car.
Go read this thread. Member gives suggestion on how to use some resistors to fool the ECU. This is before Arnott came up with their module. I think I read somewhere that is is a 5 ohm resistor needed at each wheel sensor.
https://www.jaguarforums.com/forum/x...ersion-110745/
John
John
John
John
thanks John🙂!
GrewUpJaguar
03-20-2020 04:09 PM
Donzi
09-07-2015 12:06 PM
amcdonal86
03-03-2012 11:49 AM
