A/C not working. Fixed a leak but won't recharge!
I have a 2004 XJR. The A/C stopped working a few weeks ago. I had a mechanic locate 2 leaks in the high and low pressure lines and it was replaced.
Today I took my car to shop to get it discharged and recharged but the machine couldn't fill my car up with the refrigerant. I was told it seemed like the system was clogged or blocked somehow.
What do I need to check now? switches or relays? The compressor never turned on. Please help!!
Try placing gauges on the system to see if you can get a reading. Check the desiccant bag in the condenser. It is possible that it is dirty and clogged from the leaks that you had. It is possible that there could be a cog at the condenser. Worse case could the expansion valve located behind the dashis a pain to replace. It is also possible that the valve that controls the compressor displacement has gone out which can be replaced. Or maybe the whole compressor has pooped.
Hustle Hyde (09-29-2016)
Thanks for the reply. I will forward your response to my mechanic.
Is there anything else I should be looking for or checking? Any fuses that might have gone out? If the compressor is bad would that keep the system from accepting a charge?
Any information could help me trouble shoot this problem.I do have a used compressor that I bought but just haven't put it in yet because Iwasn't sure if my compressor was bad or still good.
They should have access to the electrical schematics and manual for your vehicle.
Is he just hooking up the gauges and shrugging his shoulders, or is he telling you he checked all of the parts, listed what he checked and validated that the parts are/ are not working? Was he able to successfully evacuate the system and create a vacuum?
In order to better help you, I think we need more details on your experience with the shop since you're asking questions that would have been part of a shops standard troubleshooting.
Better still, take it to another indy mechanic for a second opinion.
So yes, clog in the system is possible (shrader valves are a common spot as is the receiver/ drier which should have been replaced when the lines were changed.) You can run a jumper to the low side pressure switch to get the compressor to run. The compressor could be shot as Blackkat mentions, but that would be strange given it was running a few weeks ago. Let's start there for now.
Let us know please.
Don B (09-30-2016)
These darn cats
09-04-2016 05:25 AM
