C2780; c2302
Old 08-07-2016 | 06:03 PM
Gr8Brit's Avatar
Default C2780; c2302
These are the codes I get using my British Diagnostics software. I'm not sure how to reset these, I tried to recalibrate the ride height, but after 30 minutes of trying I gave up. Any ideas?
John
Old 08-08-2016 | 04:19 AM
Fraser Mitchell's Avatar
OK, but can you be a bit more forthcoming on the problem you have and how this software works and where it is installed.
'C' codes: -
File Type: pdf
Old 08-08-2016 | 06:15 AM
clifton94's Avatar
Hi First thing is the compressor working ok
Old 08-08-2016 | 10:36 AM
Don B's Avatar
Hi John,
+1 on sharing with us the symptoms you are trying to resolve.
If your British Diagnostics setup uses the Jaguar SDD/IDS system, you can download the instruction manual here:
http://www.mediafire.com/download/x6...l+02_02_12.pdf
For some insights into calibrating the air suspension, see this thread on lowering the ride height. The instructions work just as well for resetting the factory ride height:
https://www.jaguarforums.com/forum/x...ur-x350-75369/
As clifton94 implied, the most common cause of the C2302 code is a worn piston ring in the air suspension compressor, which can be easily replaced with an inexpensive new ring from our forum member Andy (bagpipingandy.com).
Cheers,
Don
