C2C29016 X-358 Boot/Trunk chrome trim strip
Jaroslav Záruba (03-02-2024)
Jaroslav Záruba (05-31-2024)
Yes, there are 6 studs with nuts accessible via holes in the inner body panel. I urge you to be careful as the plastic brackets the studs are mounted in are no doubt brittle with age and there is no other way to attach the chrome strip if the brackets are broken. A new chrome strip is U$350 and I was unable to find a used one because they all break after so many years.
Jaroslav Záruba (06-01-2024)
Hi, Jaroslav,
+1 on screws and adhesives.
Actually, there are nuts! You will need to remove boot liner to gain access to nuts.
After you remove nuts, push on studs, judicially, and the piece will come out. You can clean remnant of adhesive with plastic scraper and alcohol.
To aid process I recommend to rinse operator's throat with similar cleanser, 🥃.
Get yourself some 3M VHB tape 1-1.5mm thick, clean surfaces with remaining alcohol. Works like a charm.
I did it when I was installing backup camera. Which I recommend, as you're already there.
The following 2 users liked this post by Big Koshka:
Jaroslav Záruba (06-01-2024),
PeteK812 (06-03-2024)
I just did it in my Jinxy, it wasn't easy, you have to take the trunk cover out, the six screws and then... gently, gently, gently push the chrome trim out, there is some 3M tape. I removed the trim to put a new license plate lights set, put the chrome trim back and used the same tape that was there.
First time I pushed on that chrome piece I could hear something falling through, and eventually this came out:
I suppose that it had to have broken off of the chrome trim?
I wish I could find better photos than these to confirm: https://www.autoreservejaguar.com/xj...te-lights.html
cbharley10
09-17-2023 08:03 PM
tlombard77
05-08-2011 03:38 PM
whitestype
03-24-2009 03:24 PM
