CAN BUS problems
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
The Cruise control sensor in my 04 XJR died and I found a replacement for $500 instead of $6500 from the ***********. I had it installed and had the unit configured for my car. The cruise not available is still on and I was informed that it is a CAN BUS error. Can anyone besides the dealer read the CAN BUS? I am trying to get this fixed for more than 6 months.
Did the Dealer do this work? Why is the installer not charged with making it work? It should cost about $120 at most dealers to get the CAN Bus analyzed. Generally, fixing them is correcting bad connections or wiring. I would pay the money to get the cruise working again. There is no other way around it that I know, you need the Dealer PDU to do this..
The dealership would not install the cruise unit because I did not purchase it from them. They told me it was a safety issue. They just wanted to bang me for $7k. When I went to have them install the part, I was told that they would not do it. I think I'll bring it to another dealer to have them address the CanBus issue. Thanks.
Mark
Mark
As far as I can work out the can bus is a network between modules and other systems in the vehicle where digital messages are sent around the network in the same way that computers communicate (I think).
If the component is not sending the message it may not be programmed to do it or as OLDmots says because of a bad connection.
The dealer has a computer which uses IDS Integrated Diagnostic Software to diagnose faults and reflash modules.
IDS is an expensive tool but many indepenent garages have it and hopefully will charge you a lot less for a diagnosis and cure. Good luck
Guest
Posts: n/a
From your description I am assuming you have adaptive cruise control?
If so I have a few questions,
1) You say your cruise module failed, what were the actual symptoms? message warnings etc etc.
2) Do you still have the original part if so can you post the part number
3) Would it also be possible to post the part number of the recently fitted part?
4) You say that the new part was programmed for your vehicle, the only action that can be done is to put the unit in service align mode (yellow icon flashing) can you confirm this, if so is it still flashing?
5) Why is the CANbus suspect now are there any current dtc,s that have been read from the vehicle? or new symtoms?
This is the sequence of events regarding the cruise failure. While driving one day, the center message display had the message :Cruise Not Available". WHen I restarted the car the message went away. then came back. In the begining I could "trick" the system by starting in neutral and then putting the car into drive with out touching the brake pedal. That worked for a while. I brought the car in to Jaguar and they told me they tested the cruise module. They claimed it was defective. They also told me not to fix it as the part was $6,000 plus labor. I found the exact replacement part on eBay in the UK. The part number is C2C-23960. I had it replaced by a Jag tech who configured the unit to the car. I still got the Cruise not available and the flashing yellow light in the message display. I was told that now the issue is a CAN-bus problem. I need to get the car into Jaguar so that the fault can be identified. My guess is that it is a bad connection somewhere.
Guest
Posts: n/a
Hi Mark,
Not much to go on there, the C2C code does not mean much, i was hoping for something like 4R83-xxxx with an end suffix of AC, AD AE, or something similar.
The majority of these modules are replaced when its not required.
Without reading the diagnostic trouble codes its difficult to determine whats going on, but the issue could lie any where from the cruise switches/clock spring to the brake system.
If your follow icon is still flashing then the system is in service align mode, there could be a vehicle fault preventing this from completing or more simply the new radar may not be have been levelled correctly using either a digital inclinometer or a bubble level, this really needs to be checked.
Hi 04blackxjr, I have been having the same problem and I am trying to solve it. See here for progress and codes, etc.:
https://www.jaguarforums.com/forum/s...ad.php?t=41531
Can you tell me where you bought that module for $500? The cheapest I have seen is $2400 for a remanufactured one. It is SO expensive. Any help would be appreciated.
dragonfly777
Regional
09-08-2015 01:39 PM
