Can't find Audio Source button to choose iPhone for BT music playing
I found several videos on YouTube that were in a 2007 XJ8 like mine and their Nav/Audio screens are very different. I saw a video where when you pressed the Audio button you could press CD and then a Source button appeared. You could press that and choose your already paired phone and then play music through the audio system. My '07 XJ8 does not have that screen. Is there a way to update the system? Can one use the hidden menu (ie press phone and menu then 1971) to get to a screen that allows you to choose different options to get to the screen I'm describing. I would try that, but only with specific instructions because I just got the car and am unfamiliar with all the options and don't want to press something wrong and do something stupid!!
So, again, can one either get an update from Jag or do it by one's self to get the Audio Source button so I can stream my paired phone's music inb my '07 XJ8?
Some x350's have the bluetooth connectivity option installed. It sounds like yours doesn't.
It is always possible to get an FM transmitter, or do like I did and install an aux input. IIRC getting the actual Jaguar bluetooth module that was installed in the car originally is both extremely rare and expensive.
My iPhone is already paired via Bluetooth. The issue is that the Source button doesn't appear that allows me to stream music from the iPhone as others with '07's seem able to do. My menu doesn't give that option, hence my question whether I can update the system to get that option.
I'll consider an FM transmitter, but would prefer being able to do it va the onboard system.
https://www.jaguarforums.com/forum/xj-xj6-xj8-xjr-x350-x358-28/peculiar-issue-my-x350-nav-unit-thinks-its-x400-resolved-199452/
Maybe you have the bluetooth module installed but the car does not realize it for some reason. Manually telling the car you have it might work.
Ben
I just went looking for those videos and BUMMER, realized they were for an '08 and later. The videos I had found about the '07 referred to other aspects of the Nav screen. I just got a Bluetooth/FM modulator device that allows me to stream music from my iPhone through the FM radio so that works ok. Thanks all for your suggestions.
