Can't find coolant leak
My 2004 XJR has developed a coolant leak. I can smell hot coolant when I get out of the car, and I've noticed some coolant under the middle of the car after it's parked. It doesn't leak when it's not hot. I figured the coolant was dripping onto the pan under the car and running off the back side, which is why the drip was in the middle. I knew the aux coolant pump was bad - no heat at idle - so I replaced it. (I now have heat.)
I couldn't find any evidence of a leak anywhere around the radiator or front of the engine. I left the pan off and drove the car until it warmed up, then put it back on my lift. No water under the engine anywhere, but then I found the drip. It's coming from behind the heat shield on the driver's side by the back of the transmission.
I could see it running from the heater core down the right side of the firewall behind the heat shield, but the left side? Any idea where that might be coming from?
This hose connects underneath the supercharger to the front block back to some other cooling.
Is only a $17 hose, but takes about 8hrs to replace it.
I did it last year, and changed most other hoses too, just to be sure.
https://www.jaguarforums.com/forum/x...valley-134108/
I suspect it's the hose under the supercharger. I ordered the parts from your post and started on the job tonight. It's going smoothly for the most part, but can you tell me how to get the false plastic firewall off? I got both side around the cabin filter and brake booster ok, but how does the center section come off?
I've read everything I can find. Closest thing that talked about the center section was in a thread that said you can't get to the EGR valve unless you take the center section of the plastic firewall off, but it's not too hard. I must be missing something, because I'm finding it pretty darn hard.
His post:
NCamie
10-31-2015 10:38 AM
