Can't get my cracked windshield replaced 'cause they can't get the "clips."
https://parts.jaguarlandroverclassic.../brand/jaguar/
That's the link to the windscreen parts list, you should find the part number you need there and, fingers crossed, find the parts you need.
Don,
You did not realised, probably, but you are posting on x350-358 forum, that is 2003-2009 models....
You may want to post here:
https://www.jaguarforums.com/forum/xj-xj8-xjr-x308-27/
You're going to get more relative help...
Thanks for the link. The link is for the 2003 model and I have the 2001. There is no mention of clips in the 2001 page from these guys whereas the 2003 page has multiple clips listed (and they are inexpensive) so I'm not sure what's going on. Would the 2003 parts fit? If I buy the 2001 rubber seal (Almost 300 pounds) does it come with the clips? Any clarification would be a great help.
and yes, there are no clips listed apart from one. I would say that the chrome moulding (or windscreen finisher, as it is called in the catalogue) is inserted into the glazing rubber itself, without any clips. This method was quite common in the past.
Best regards,
Thomas
Yes, you are in the wrong forum, but I had a look at the Jaguar parts catalogue
Best regards,
Thomas
Best regards,
Thomas
No problem at all.
I suspect that the trim would not glued on, but that there would be a kind of channel in the windscreen rubber into which the trim is inserted. In that case, the trim would have an appropriate form and not be flat on the "inside" (towards the rubber).
Best regards,
Thomas
Best regards,
Thomas
abonano
05-10-2024 04:46 PM
Johnny Tundra
09-08-2019 11:20 AM
bachtopa
02-06-2013 11:13 PM
