Car Bucks When Cold | Please Help
My '04 VDP has a slight buck when it is cold and I drive it on the HWY. The car feels like the idle is constantly going up and down like it can't settle at smooth speed. At first I thought it might be tire/road noise, but it is not. It takes some time for it to smooth out. It is quite pronounced and I am worried.
What do you think it could be? I would like to have a grasp on the problem before I go to the dealer or independent Jag repair shop. The car has 52K miles.
Do you by any chance have one of the first of the '04s (VIN lower than G12000?). I believe this problem was much more prevalent on the earliest of the XJs. I do also, and have/had the same problem you describe. I had the powertrain control reflash done (actually a reflash of the engine computer AND the transmission computer), which improved the problem somewhat, but I still have some "bucking" when cold. I "sort of" recall having read somewhere that the only way to cure the problem completely is to replace the torque converter, which is OK if you're under warranty but I'm sure WAY $$$$ if you're not. My car is out of warranty, so I just live with it (only lasts for ~5 minutes and only noticeable at constant speeds when warming up).
BrentGardner
28
04-26-2024 03:08 AM
