Car not starting after key fob replacement
Hello there everyone, can someone please help me? My original key fob has stopped working. I ordered one on ebay switched out the blades only to find out that the new key fob was not compatible with the car. I switched the blades back and try to start the car it will not start. I tried to reprogram the old fob and i guess since it is sticky and one componet in there needs soldering it will not pair. I used the light blinking technique to reprogram the fob and i can hear the last two beeps like it is in program mode, however when i push the buttons on the fob they don't cause any reaction. Is this causing the car not to start? If i get another fob that is compatible will that work. Please help me.
That's what i was thinking, it's the same blade. It turns over with all lights but it says nothing. It was cranking before i switched the blades. I read somewhere that whenever you insert a new key, the car will remember that key. I did insert the new key but it didn't turn because it was not cut. So are you saying that even if i had the old key on the new fob that wasn't compatible or the original fob that has stopped working it should still start? So it doesn't need reprogramming?
1. It's not the key that needs programming (you can't 'program' keys) - it's the car that has to be programmed to recognise the key.
2. The fob has two chips in it, and both need to be registered with the car.
One is the remote chip which is battery powered and locks and unlocks the doors, and is nothing to do with starting the engine.
The other is a transponder which is energised by a coil around the ignition lock. Think of it as the same as an I/D chip that you'd have injected into a cat or dog's scruff. That's the beastie which tells the car that the mechanical key is genuine.
If the transponder isn't registered with the car then it won't start even with the correct mechanical key (your situation, I think).
If you have two keys with transponders already registered in the cars electronics then there is a procedure for registering further key transponders, but it won't work if you only have one, or none. In that case you need to use Jag software called SDD. There are quite a few posts about this if you use the 'Search' facility on this forum.
The following 2 users liked this post by Partick the Cat:
karenh (09-02-2020),
motorcarman (09-02-2020)
Hi Partick, will the IDS work for this registering procedure?
Because the lower part of the fob only has the 'remote' chip in it and that has nothing to do with starting the car.
Starting is a function of the transponder which is hidden inside the top part of the fob, the bit with the key. You need a key (which fits and turns the ignition lock, obviously) with a transponder attached, a transponder which has been 'programmed' into the car's system.
Partick is absolutely correct. When I bought a 2nd key, I had to take it to the main agents for programming so it would work with the car. They obviously had the car details to work with. They also told me that any lost keys will no longer work when the new keys and any existing key still in use, are re-programmed.
UPDATE:
First i would like to say thank you to all of you guys for your support and time. The car is starting now. Somehow when i was changing the blade it came out and i sat it down and didn't really pay any attention to it. I tried to take the fob piece off first, thinking i was unable to knock the pin out to remove it that way and that's how i ended up with that part loose. When you responded about that the transponder, it donned on me then. Thank you so much
Partick the Cat (09-04-2020)
