Castrol Response Super DOT 4 brake fluid
Old 07-17-2011, 11:03 PM
plums's Avatar
Received 2,184 Likes on 1,624 Posts
Originally Posted by jahummer
What are you using for brake fluid? Jaguar insists it must be Super DOT 4 and all I can find is Castrol Response at $35 a litre with shipping. There must be a cheaper way. Can I use DOT 5.1?
Jaguar does specify the exclusive use of Super DOT fluid and there are a handful of manufacturers making the fluid. Checking spec sheets indicates there IS a difference and for the few dollars more, I would rather lean towards the specified fluid.
So, which is it?
Unless you drive right to the absolute limits and beyond, it doesn't really matter. And, if it did, you would definitely know because you would be changing the fluid every week.
"super" has no defined meaning in the specification, DOT, SAE, or Jaguar.
Both the Ford and BMW fluids also far exceed their claimed DOT compliance level. They are also both dirt cheap. The BMW fluid is rebadged ATE. The Ford spec is available from the usual aftermarket brands. It just says "meets FORD specification XXXX, boiling point 550 degrees F.".
Old 07-18-2011, 02:18 AM
DB6's Avatar
DB6
DB6 is offline
ud
Default plummy...shut up, you sound like Buzz Lightyear.
may be it is a BS overkill, who knows..
but for a few $ why not go with the recco,
Originally Posted by plums
So, which is it?
"Unless you drive right to the absolute limits and beyond", it doesn't really matter. And, if it did, you would definitely know because you would be changing the fluid every week.
Old 07-18-2011, 03:43 AM
avos's Avatar
Received 1,068 Likes on 761 Posts
I always use the ATE fluids, they have a blue and gold colored version, so use them one after the other (easier to see this way that all fluid has been exchanged)
The specs are also very good, better then Castrol anyway. Here an example:
http://www.tirerack.com/brakes/accessoryDetail.jsp?ID=21
Old 07-18-2011, 08:51 AM
jahummer's Avatar
Received 2,382 Likes on 1,492 Posts
LOL!!!
NOTE TO FLORIDA RESIDENTS ONLY: ATE Super Blue Racing Brake Fluid,
due to its blue color, cannot be registered in and is not DOT-approved
for street cars in Florida.
Are they serious?
Old 07-18-2011, 11:55 AM
Received 2,263 Likes on 1,845 Posts
That's what I came up with also. I'd use DOT 4 and be done with it.
Old 07-18-2011, 12:24 PM
DB6's Avatar
DB6
DB6 is offline
ud
Default Hmmmmm
So even though the manufacturer states use super dot 4 and it is available from many sources at a price of around $10.00 pet litre you would not use it.
This is peanuts compared to many of the repair and maintenance costs on these cars.
Old 07-18-2011, 12:53 PM
Brake fluid, like many other safety related items, is federally regulated and must comply to a specification. Current specs applicable to brake fluid are DOT 3, 4, 5 and 5.1. There is no 'super' DOT 4 spec, unless you can point me to one.
My manual also mentions a specific brand and model of tire. Should I stick only to that specific model even though it is outdated and doesn't reflect the full range of choices in the market?
Do you?
  #28
Old 07-18-2011, 01:11 PM
jahummer's Avatar
Well, I am fully aware of DOT specs, but there are fluids available that exceed those specs and since they don't cost that much more and Jaguar recommends using them, why not?
Old 07-18-2011, 01:13 PM
jahummer's Avatar
Actually, there are some tires that do not work well with our cars. I know I ran into this problem and the dealer showed me a TSB saying which tires were and were not recommended for the vehicle.
  #30
Old 07-18-2011, 01:36 PM
Then you've ruled out 5.1 since it's not what Jaguar recommends/'insists' upon?
Please understand that people are simply trying to help here.
  #31
Old 07-20-2011, 10:42 AM
kthrash's Avatar
I bought Pentosin Super DOT 4 in a 1litre bottle for $12.99 here:
Pentosin - Super DOT4 Brake Fluid (1 Liter) [ BF-1L ] - UroTuning.com - Parts for VW Audi Porsche BMW
I could not find it locally and my local NAPA dealer did not carry it.
  #32
Old 07-21-2011, 07:48 AM
oldmots's Avatar
I use the Pentosin fluid and buy it off the shelf at BAP/Geon.
I looked at the specs on tghe Pentosin fluid and compared them to other fluids and it looks like the word "Super" on the can means no more than if it said "Hotdangdiddly". The ATE blue fluid has higher specs and it is advertised as DOT 4.
  #33
Old 07-21-2011, 02:26 PM
This is essentially the point I was trying to get across above. From the specs I've seen, ALL the fluids significantly exceed DOT4 requirements. Some manufacturers make a big deal of that, others don't. If the cars actually needed fluid that exceeded DOT4 spec, they would specify the next step up which is 5.1
  #34
Old 07-21-2011, 06:02 PM
jahummer's Avatar
Yup, I decided to go with the ATE fluid.
  #35
Old 07-21-2011, 09:22 PM
chadmc5c's Avatar
Default brake fluid
For my 06 xj8 I use ATE Blue. I get it at Pelican Parts and use it in several of my cars. Also use a power bleeder which makes fluid flush/change a breeze. Worth the 60 bucks I paid for it.
chad
(for "break" fluid I use Sierra Nevada Pale Ale)
  #36
Old 07-21-2011, 11:13 PM
DB6's Avatar
DB6
DB6 is offline
ud
Wotaborintrhed
FKKNHELL Jahhummer
you better start shopping for Christmas now.
  #37
Old 07-21-2011, 11:46 PM
Isn't SNPA one of the most wonderful reasons for being alive? I've got a stash of 2005 Bigfoot that is being saved for a special day.
  #38
Old 07-22-2011, 02:57 PM
jahummer's Avatar
Originally Posted by DB6
Wotaborintrhed
FKKNHELL Jahhummer
  #39
Old 07-22-2011, 07:53 PM
I didn't understand either, nor did Mr. Google.
  #40
Old 07-22-2011, 10:18 PM
DB6's Avatar
DB6
DB6 is offline
ud
just being sarcastic...
"Wotaborintrhed"
as in what a boring thread
FKKNHELL Jahhummer
Swear swear swear..Jahummer
and better start shopping for Xmas:
as it takes Jahum 3 weeks to buy some brake fluid...
Sorry!
Quick Reply: Castrol Response Super DOT 4 brake fluid
