Cat is bad will 49 state one work??
I have a 2006 XJ8L that i just found out is a California spec car in New Jersey. The Cat is bad on the pass side, so I ordered a new cat that is 49 state legal. will that work on my car and NOT cause the Ck engine light to come on? New Jersey is not as strict as Cal. so a 49 state Cat would pass here. Any one know for sure?
Received 2,625 Likes
Bigvettefreak (04-24-2016)
I also have PO420 code and a check eng light ('07 XJR 90K miles); Bank 1 (RHS)
In researching this forum, seems that the RHS cat is a semi frequent X350 failure. I did not find anyone successful in fixing problem by swapping or replacing O2 sensors
Are the OE sensors not Denso? Why use Bosch? Are they more tolerant?
The one thread I found actually reporting, the RHS cat was obviously bad upon removal
Looking at aftermarket cats on Ebay, I am tempted to replace both sides with (weld in) ~200 cell (higher flow) cats. Anyone done this?
hisport (04-25-2016)
This is not necessarily true. Especially if the universal is used. The lambda voltage from Bosch sensors, can cause significant issues. Wideband voltages, which is what is currently being used by Bosch's current design has caused problems for numerous vehicles. Denso's are the OE and cost $48 for downstream, and about $100 for upstream.
Bad cat...
Regarding fuel trims:
I have a cheap OBDII/CAN reader, but don't think it is capable of much other than generic code reading. I have used VAG/COM (on a laptop) for german cars; it is excellent
What is the best DIY diagnostic system approach for Jags?
Thanks. Just FYI, I did try swapping the downstream O2 sensors; still PO420 bank 1 (RHS). Hence my search for a replacement cat
Sorry to hear about your cat.
hisport (04-26-2016)
silversurfer1221
04-06-2016 05:26 PM
