"CDC Error" when I select the CD player
I get this error when I select the CD player. I think a CD is stuck halfway into the player part, because when I try to remove the cassette by pressing the button it does not come out. I presume I now have to remove the whole unit and dismantle it to release the CD, correct ?
Received 2,192 Likes
it happens to me.
In fact, the Stype, Xtype and X350 they all use the same CDC. They all have the same problem.
I found out this issue always happened while I am selecting the CDs. The dealer told me maybe the magazine out of shaped? They ask me to replace a magazine and it will cost me around $120 USD, but I did not do that.
Many years ago, my way is to insert a blade tool to push the magazine up or down even pull my cd back to magazine, it works sometimes.
Actually I have changed 2 CDCs already, they works perfect at first, and finally I found the way to solved this problem is to disassemble CDC unit and lubricate the gears inside.
For now, it never happened to me again.
Guys, many thanks for all this advice ! I am reluctant to go out there and do anything because here in England it's not so much the cold, but it is terribly damp and wet ! The car is too large to get into my garage which is heated. Actually the Midget is in there right now waiting for warmer and dryer days.
Other thing I get when I turn on the rear screen heater is terrible "fish-frying" noises on the radio - "sch-schschsch-schsss". It drivers you insane when you're listening to some nice music. Only thing was it seemed to carry on even with the screen heater off !! Now it seems OK.
Maybe I'm not being kind enough to this kitty.
Thanks to all who posted comments re the CDC Error messages. I had that problem yesterday, and followed advice to tap the cdc magazine when trying to eject it, and voila, out it slid. So, add one more "It worked" to the list of those who've experience the problem. Thanks.
HoCojimjag
2005 S-type 4.2L
HoCojimjag
2005 S-type 4.2L
Come in Fraser, you can DO this! As several forum members said, a little patience, a thin blade or small screwdriver + a flashlight (you folks call themselves "torches" but I always picture those along with pitchforks and angry townsfolk, lol), and you will be back in business. It's easy to see which tray is stuck, then just gradually slide it back into the unit, .01 mm at a time, it feels like. Once it's all the way back in the magazine, eject will work, then just make sure all the discs are laying flat in their respective trays.
You know why this happened right? Just like you, the kitty doesn't LIKE being out in the damp and wet while that little MG is warm, dry and appreciated! It wants ATTENTION!
Better go do it now, before it really throws a tantrum. These cats can get pretty mean when they want to.
FS[Western US]: JAguag x350/358 CDC Player Brackets
perezal
12-24-2015 04:20 PM
