CEL, restricted performance, Stall
Hello all,
Unfortunately I have some more problems with my 06 XJ8. About a month and a half ago, the car had a weird idle and would grunt slightly. I thought nothing of it until the CEL came on. We had it fixed and the mechanic claims it was a spark plug. I drove the car home and it drive like a dream. Then the next day, I was driving it and the CEL, restricted perf lights came on and the car had a very rough idle. There was grunting and when then it stalled. We are going to send it to a Jaguar dealer and see what it can be. I am very nervous, cause I know it probably will hurt my wallet pretty badly. Can it be just a coil or will it be something more serious (theottle body, tranny destroyed). If someone can deliver me some type of good news, I'd appreciate it.
Best regards.
Best regards.
https://www.jaguarforums.com/forum/x...k-links-20085/
That will assist you in your search to find the issue with your vehicle.
My first action would be to check the Crank amps and charge in your vehicle battery.
Secondly, using a standard OBD II reader will not help much as the only fault codes for engine problems. You will need to get a more specific OBD reader to see ALL of the fault codes.
Can you detail in what order the sequence of events happened and over what period of time?
JimC64
10-13-2015 07:08 PM
