Ceramic Brakes for 04 XJ8
Hello, all. I've had my '04 XJ8 for three weeks now. Took it on a 500 mile road trip this weekend and am totally wow'd by the performance, especially the pick-up when passing a car and we're already going ~75 MPH!! And I still had a trip average of 26.2 mpg.
Anyway, when I returned, I noticed lots of brake dust on the panel behind the rear wheels. It's not oily, so I'm assuming it's normal dust, but it seemed like a lot.
Anyway, I'd like to replace the (I assume) OEM semi-metallics with ceramics, but I did find one site which warns against replacing semi-metals with ceramics. Yet, I find ceramics for 2004 XJ8 front wheels, but not back.
Could someone here give me the straight "skinny" on this? Thanks, in advance.
Mitch
Mitch
Factory pads create a lot dust. It's mostly the binding compound (mostly resin) that creates dust. Ceramic pads because they typically are of higher quality and contain less metal particles don't dust as much as organic pads. You can get high quality metallic pads that produce little also.
Disc Italia makes a very high quality pad in both a ceramic and kevlar titanium compound for front and rear brakes for the X350. You will get better bite, longer wear and slightly more dust from the kevlar titanium compound than the ceramics. For my money I would go with with the kevlar titanium compound. I have been running them in my '04 XJR and I am happy with them. You will probably notice a slight drop off in braking performance if you switch to ceraminc pads.
The only high compression molded brake pads I know of which are the highest quality type of construction for the street are made by Performance Friction and Disc Italia. Unfortunately PF doesn't make pads for our cars last time I checked. They do make pads for the X308 but not the X350's.
Just for reference if you are interested:
Rock Auto - brake pads
Akebono EUR1062 - $85.79/set
Akebono EUR806 - $66.79/set
R1 Concepts - rotors
POEF06471 - 120.61077 Premium front rotors - $174.90/set
POEF06471 - 120.61062 Premium rear rotors - $74.36/set
(You can have these rotors drilled, cross drilled or both if you want. I got the smooth surface rotors.)
Thanks!
mls0036
10-17-2015 10:03 AM
