Changed leaky front passenger shock and car sits overnight
The front end drops down noticeably. When i park the car at night and come back in the morning is when it happens. No problems when i am using it throughout the day and no air suspension fault message comes up as it did before i changed the bad passenger side shock. But now when i goto my car in the morning, it looks like a 70's drag racer with the rear up but the front down! lol
It wasn't likely the shock--the suspension exhausts air through the pump which is located in the driver's side (left hand) bumper. When you jack it up, the car doesn't immediately go into jacking mode, first it tries to adjust itself then it stops when it realizes it's being lifted.
So I did some more investigating and I hear air leaking from the hose fitting on the new passenger side front shock that I just installed! During installation, i fitted the new o ring to the hose before installing, and upon tightening the hose bolt, it seems that it turned the entire fitting after fully tightening. Is this a problem?
