Changing screen wash pump
Old 10-11-2014, 06:15 AM
twojags's Avatar
Red face Changing screen wash pump
Hi all.
I have a 2007 tdvi XJ 350 and we are trying to change the screen wash pump. Where is it located and do we have to remove the wheel arch liner?
Thanks for your help.
Old 10-11-2014, 06:36 AM
GGG is offline
Received 16,852 Likes on 12,186 Posts
Angie,
I've moved your question from General Tech Help to X350 forum. Members here with the same model will be able to help.
Old 10-11-2014, 06:42 AM
GGG is offline
From JTIS for the 2005MY - your 2007 should be the same ......?
As you suspected, the RH front wing liner has to be removed.
Old 10-11-2014, 06:44 AM
twojags's Avatar
Thanks graham.
Old 10-11-2014, 04:11 PM
meirion1's Avatar
Err.......When you pull the pump out (just pull it out of it's rubber grommet)-you lose all
the fluid.Have a container ready if you want to save it.
bamforp
09-26-2021 08:04 AM
Sprayall
05-30-2021 08:13 AM
dsnyder586
04-04-2019 02:38 PM
tberg
09-07-2015 07:32 AM
Sprayall
09-03-2015 07:49 PM
Quick Reply: Changing screen wash pump
