Changing VDP Spark Plugs
Has anyone changed the spark plugs on their 2004 VDP themselves? I changed mine, and all went well EXCEPT for the left side rear (drivers, US). I actually destroyed the insulation on the engine side of the composite shields for the brake master cylinder trying to get a tool on the plug. I ended up removing the panel which was not obvious until the insulation was unintentionally removed. I used various lengths of extensions and swivels, but seemed impossible at the time. What is the correct procedure? The only thing that comes up on a search is plug type.
Thanks for any insights. The job is done, but curiosity remains.
