Charger vs Cigar Lighter Location (rear)
I'm a little confused as to the location of the Phone Charger in the rear of the Center Console. I know one recepticle is for the Cigar lighter and the other a Phone Charger. The problem I'm having is that the LEFT one does not work at all; with either the Phone or Lighter. The Right one is always on when the car is running (so the charger could work there).
Can anyone tell us how your rear console is configured? Is the left side the Cigar Lighter or is it the Phone Charger? Maybe it doesn't even matter at all, frankly, since neither are 'hot' when the car is not running!
It does look like my left side receptical is not operable for either use; so I'll likely have to get into the console to investigate. I use the right side for the Phone Charger but am not sure this is correct.
I've looked at photos of cars on Ebay to see how others are configured but unfortunately there appears to be no consistancy. On some the Right side is the Phone Charger and on others, it is the Left side.
I doubt it matters, but my center rear console has the two recepticles and two rear seat heat buttons only; I do not have the rear A/C controls.
BTW, does anyone have advice as to how to remove the Center Console?
Here is the info and there is a difference between the two. It looks like they are wired differently between cigar lighter and power point. All of theses fuses are in the trunk distribution or rear power distribution.
F43 is rear cigar
F44 is front cigar
F26 is rear power point
F25 is front power point
F43 is rear cigar
F44 is front cigar
Drew, you were right! I checked the fuses and sure enough the the rear Accessory Power fuse was blown; replaced it and it seems to work just fine now. BTW, the Power outlet is on the Left and Cigar Lighter is on the Right side.
Interesting, when I pulled out the unit from the Center Console, I noted that both the Power Outlet and the Cigar lighter are the same identical part number; yet the Owners Manual cautions not the use the cigar lighter for plugging in accessory items. Makes no sense to me.
Anyway, thanks for yur direction.
KarimPA
09-12-2015 08:15 AM
jagent
09-12-2015 01:40 AM
