Charging point
Charging point
Hello
I do not use my X350 that often and for that reason I have connected it to a trickle changer in the boot.
Problem is that i need to park my car at an incline towards the garage meaning water is gathering in the cavities towards the rear screen. Consequently it leaks through the seam where plates are bonded and into the boot.
parking my car the other way around would party solve the problem, but then the cord to the changer is then too short.
Are there any connection points under the bonnet which could be used, alternatively cigarette lighter??
Br Martin
Br Martin
The seams are sealed and car seems to not leak anymore. Also connected charger in the engine bay. Used the maxi fuse connection for + connection and the strut tower bolt for -. Now I can park the car with front towards the garage and charge the car and at the same time avoid water gathering under the boot when raining.
Martin
Martin
XJR 308
12-03-2016 03:47 PM
