Clarification: Adjusting High Beam Headlights
I have read a fair amount of, if not conflicting, you could say differing info on our Headlights and methods to adjust them. Here is my issue, and I am hoping to get some clarity on this.
There are some eary cars that use the air suspension to level the car, and thus the headlights. They do so in a smart way, always leveling the rear of the car first, and then the front in an attempt to mitigate blinding oncoming drivers. My car, a 2007 Vanden Plas doesn't have any of this, nor does it appear to have any automated or motorized headlamp aiming mechanism. What it does have is a 6mm hex fitting that allows vertical adjustment of the low beam HID (previously called "Xenon") headlights. They work well, are bright, white and focused decently through a projector lens.
The high beam adjust is in the middle of the housing - The presumably High Beam adjust is over the inner housing - except it doesn't appear to do anything - I have spent a lot of time running the adjuster from one extreme to another - with virtually no notable effect. I will post a few pics of these when I get home from work today. Except my high beams leak light pointing almost straight up.
Any thoughts, experiences, instructions etc. would be SO appreciated!!!
![](https://cimg2.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/20180824_101500_2b242e99e9e85da1257a48221203fb64d027b738.jpg)
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1358x1810/20180824_102906_84fe45e02f1c28a5086d2634bd6ddf495734ce22.jpg)
Note that BOTH of the inner adjustments toward center of car do nothing. There is no problem with my headlight aim at present. I just need to find out what the inner adjusters do, as my high beams seem to leak a bit of light upward. Anyone?
