clear coat DIY
The roof of my 04 XJ is fading away. Closer look, the clear coat has evaporated, leaving behind a dull British Racing Green. Looking at a YouTube video or two and I learn that there is available a "2K" aerosol wherein you mix part a and b right in the can itself. It is stronger that way and can produce near superior results. About 20 buckaroo and plenty enough for three coats up on the roof y'all.
Can't wait to give it a spray to harmonize the exterior !!!!
I've used that stuff when I only have a small panel to do and I don't want to setup/clean my guns. Works really good if you know what you're doing! You will want a respirator since it is 2K and therefore has all those wonderful chemicals in there. Also, I don't know exactly how big the cans you are getting are, but I would say to do the entire roof properly (two coats) you will need at least 3-4 cans, maybe more. You don't want to be in the middle of the job and realize your short! Best advice I can give is make sure to prep really good. Make sure to sand smooth with 400 grit and get any peeling clear off (careful not to go through the base coat). Clean it good, tape it off and then go for it. As long as you are careful, it can be done. Hey, I've resprayed my SV8 in an old garage, a mustang twice and am just working on our STR getting ready to paint it (hail claim) amoung other random panels on many other cars. Have fun! In the end, even if it goes wrong, you can always sand it down again and try all over again. That's how I learned.
paydase (06-11-2017)
It is the Ultraviolet light in sunlight that kills off car paint eventually and fades the colours. This can take many years and in places with little sunshine, may be decades.
If you're going to DIY it, you need to get all the old clearcoat off.This will be difficult to do without removing some of the basecoat, so probably best to get a reputable paint shop to do the job.
