Climate Control Blower went out!
Been two years without a fan. Have to haul *** in the summer and winter to make it blow enough air through to keep me cool or warm lol. So I did a search, I know I have seen this before on here but came up empty for some reason..surly operator error on my part as I know this has been discussed many times here. So, I replaced the motor, because it made metal on metal sounds, like a bearing was going out. Still does not work, at least that's what the shop said. Hopefully they did indeed do this as I purchased the blower used:
1-How do you bench test the blower? Can you just hook up a lead from a 12v battery to the leads on the blower?
He said I need to change the module, said you always do.
2-What does it look like, what is it called, and where is the best place to get it?
Any links to those step by step instructions will help as well.
Thanks!
Thanks!
Camnelson324
09-27-2015 08:48 AM
zdrapec
09-25-2015 05:49 AM
