Climate fan control
Climate fan control
Hi
I have a strange problem on my 05 super v8. If I set the climate control to full auto it will speed up the fan to 100% and never regulate it down, its like its never reaching its temperature.
Its winter here so im thinking that maybe it struggle to get warm, but even with 20c on the setting it will never reduce the fan speed. It blows warm from all vents except the ones in the dash. If i go to climate setting and choose the dash vents it will blow warm from them but never with the vent settings on auto.
Have anyone experienced this and have any suggestions on were to start?
Does the heating work on manual ie the heat varies with the set temperature?
If so the temp. sensor will be working.
Possible fault in blower control module.
Scan for codes first.
https://www.engine-codes.com/b2514.html
Andrew Pearce
11-02-2015 02:35 PM
NTL1991
XJ40 ( XJ81 )
10-28-2013 09:37 AM
