Clock Lamp / Light Is Out / Not functioning
Greetings,
I have an '06 XJ and the lamp that illuminates the clock is out. I don't know why it isn't working. The clock is otherwise functioning.
A review of the service manual suggests replacing the light requires substantial disassembly of the console and dashboard.
My questions are:
Can the lamp for the clock be replaced or is the lamp with the clock as a sealed unit or otherwise and the clock assembly would require entire replacement?
is there access to the bulb, or clock, without dismantling the console and dashboard?
If disassembly of the console and dashboard is required, are there any other lamps that would be exposed and prudent to replace?
My questions are:
This has been mentioned on the UK forums several times. The bulb in mine packed up at one point, it was annoying but when the car went in for some other things I had them fit a new bulb. Apparently it is not too difficult but I did not get round to it as it is a bit time consuming.
I think you have to remove some of the console and then the wood around the clock and vents, then that particular unit can be lifted out to gain access to the actual bulb.
This link may help you, quite a few remarks on it to read through
https://www.jaguarforum.com/showthre...ght=clock+bulb
Try this one
Jaguar XJ 1997-09 X308 X350/X358 Dash Clock Green LED Light Bulb C2C3441 2721MF | eBay
not sure of the color match but others on the Uk form have used it
oh, sorry wing just realized you were already on the Uk sight
At $20.39 each, with tax included, i'll pass.
Looks like the 2721 MF's from O'Reilly's.
Might work after all, just not quite the same, will check tomorrow.
Meanwhile i have a Land Rover clock bulb ordered.
That one looks like it will be a much better fit, if its the right size.
From a vender an hour away, so it should be here in a few days.
It is a bit fiddly, but perfectly do-able. Centre Console has to come out and then all the dash wood trim. Then a few screws and a bit of wriggling to get the clock out. The biggest challenge is finding a suitable replacement. The exact replacement is no longer available. The LED ones are too bright, and the filament ones claimed to fit, don't quite fit. I eventually managed to get a clear filament one that fitted and squeezed the green cover off the old one and onto the new one. And it's great to have an illuminated clock back!
J.A.G. (01-10-2022)
