Clock Light - How to change the bulb?
Old 10-17-2011, 12:18 AM
04XJ8's Avatar
Default Clock Light - How to change the bulb?
Has anyone changed the analog clock illumination bulb? I miss not seeing the time at night. Any diagrams or advice on removing / installing would be extremely helpful.
Thanks!
Peter
Old 10-22-2011, 10:52 AM
Glendoramike's Avatar
YEAR AND MODEL PLEASE. There is a download for X350 models' shop manual in this section of the forums. It is in pdf and you have to look something up in the index and note its number i.e. 72.50.03 and then do a search for that.
Old 10-22-2011, 11:00 AM
If your handle of 04XJ8 is your model then you can use the X350 shop manual. I took a quick look and didn't find the info, but that doesn't mean that it isn't there.
Old 10-22-2011, 12:08 PM
04XJ8's Avatar
Yes, it's a 2004 XJ8. The manual is the same thing that's in the glove box. It doesn't have any details on replacing dash bulbs. I was hoping somebody had done this before. Thanks for checking!
Old 06-11-2013, 09:09 PM
kchirume's Avatar
was wondering if you ever figured out how to fix that light, my clock light is out too
Old 06-11-2013, 09:56 PM
Gippsland's Avatar
Not much help I know,mine is out too. I "googled" it and found the procedure,bit tricky though.
Want I would like to do is use an led globe but I can't find what size it is. Any-one know?
Old 10-09-2013, 06:27 PM
AhwatukeeAl's Avatar
Smile Changing XJR clock bulb video
Here's a video I posted on YouTube.
Also found that a Sylvania 2721MF is a usable replacement.
The following 6 users liked this post by AhwatukeeAl:
BabyKitty (03-19-2014), dakico968 (03-03-2020), doc (10-10-2013), Gippsland (10-11-2013), kiznarsh (08-05-2021), tomfurie (06-07-2017) and 1 others liked this post. (Show less...)
99xk8guy
06-05-2023 06:28 AM
Jpav27
07-31-2022 06:43 AM
Shawn Svacha
11-04-2019 02:47 PM
afterburner1
12-16-2015 12:12 AM
bdboyle
09-04-2015 06:16 AM
Quick Reply: Clock Light - How to change the bulb?
