Clonking noise on front driver wheel - still chasing the problem
#43
didn't think a cooler line would be the cause of the noise, unless it's securing mount was really loose.
Did you have the dealer, or at least a ZF experienced tranny shop refill your transmission? I bet you're levels are off if you didn't. Its a precise method to get just the right amount.
#45
#46
Long shot, but in the essential buyers guide by Nigel thorley he mentions a hidden section of aluminium riveted to the main structure and the bumper bolted on the other end. This area is intended to collapse in an accident.he says a clicking sound of clunk from the front of the car is caused by the rivets loosening on the super-structure. These rivets can be drilled out and replaced by bolts which is a recommended jaguar fix. Probably not this but worth a look?
BrentGardner
28
04-26-2024 03:08 AM
Fraser Mitchell
10-01-2015 04:06 AM
