Close Sunroof via FOB
If I hold down the unlock button for a few seconds it will open all the windows and sunroof, but doing the same with the lock button will not close anything. I can close all buy holding the key in the door in the lock position.
At least at Mainline Jaguar near Philly, they said it wasn't possible. This is a misstep in the design. Keys and locks are primarily used to keep someone out. This lock allows you to open all the locks, windows, and the sunroof remotely, but the reverse is true for everything except the sun roof. The sunroof requires the key to be held in the locked position in the door.
This would be a sweet mod though, I wish I had the expertise to pull it off.
Key transmitter: Press and hold the lock button for longer than 2 seconds to close all the electrically operated windows and sunroof (if fitted in one shot operation).
Pressing any button again while global closing is taking place will stop all movement.
You can use the lock/unlock button on the center console in the same way.
FS[NorthEast]: 2008 XJ Super V8 - Black on Cream
sg997tt
10-09-2015 10:57 PM
Jzar
09-27-2015 02:55 PM
