Code Help - P0171 and P0174
Guest
Posts: n/a
Check Engine Light came on in my 2000 Jaguar XJ8 with an amber restricted performance light. Engine light has been on a couple weeks and the restricted performance warning comes on every once in a while during my drive – I drive 70 miles to and from work. Have noticed a kind of bump in acceleration at high speeds (don’t know technical language, sorry).
Autozone read the codes as follows:
P0111
Unknown – it would not list info for a Jag
P0171
The powertrain control module uses the O2 sensor to calculate the air/fuel ratio of the engine. The computer has recognized a rich or lean condition on one engine bank only.
P0174
The ECM has detected rich or lean air/fuel ratio condition on bank two.
Probable Causes for P0171 and P0174 said:
“If bank one and two codes set together suspect fuel pressure or MAF Sensor."
I used a fuel injector cleaner recently and the engine light clicked off for about a day. What could be the problem here? Any help is much appreciated. Thanks!
-Stacey
P0111
P0171
P0174
-Stacey
Guest
Posts: n/a
jag_genius - in your opinion, its more likely to be the MAF sensor than the O2 sensor? that is not a cheap part for me, is there any way to check whether it is working properly orare the diagnostic codes clearly tellin me, hey its not working? (i am tryin to get the prob fixed as cheap as possible and as a do it yourself) -- thanks!
Guest
Posts: n/a
My 2005 XJ8 drives perfectly after only 72000 miles, but throws the two 'lean mixture in bank ' codes. I didn't believe them. I started on a fixit trail, by replacing the MAF sensor. No difference, just a waste of money. Before exploring the fuel filter, the O2 sensors and all the expensive solutions, the problem has gone away. My conclusion: Its the ethanol in the fuel. Now that gas prices have fallen so drastically it is no longer economic to add up to 10% ethanol, so I am now driving on high-octane pure gasoline.
The other useful tip is to reset the ECU by disconnecting the + and - battery cables, and connect them into a closed loop (Not connected to either battery terminal).
Turn on the ignition and all lights...nothing comes on, of course, but it removes all static from the circuit. Hold for maybe 4 minutes. The reconnect the battery cables to the battery terminals.
Bob Gelston
09-14-2015 11:08 PM
OkieTim
09-08-2015 04:48 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
