Code P 2444
Code P 2444
Hi everyone can anybody please let me know how to replace my secondary air pump and where it is located on my 2005 jaguar X350 V6 I had my EML come on 3 days ago car still drives great no symptoms what so ever so please can anybody give me any information regarding this code will help as the code is saying air pump stuck on regards Graham
Graham,
I've moved your question from UK & Eire Region forum to X350 forum.
You have a better chance of Views and Replies posting TECHNICAL questions in the MODEL forum. The REGION forum is intended for questions about recommended specialists, meetings and other geographically relevant topics.
Graham Sears (03-29-2021)
The secondary air injection pump is in the right front bumper. To access, you need to remove the undertray that covers the bumper. I believe the relay for the AIR pump is located next to the pump motor.
P244400 - Secondary air injection system pump stuck ON. Possibly causes: Secondary air injection pump control circuit: short circuit to ground.
You should easily be able to hear if the AIR pump running continuously. It will normally run for 30 seconds or so on a cold start then shut off.
Graham,
It's your call if you want to leave it unrepaired. I couldn't say whether this will become a money pit or not. Jaguar has never been synonymous with economical repair costs.
Hi i
Hi just got car back from garage £200 later every thing is fine they checked pump , relay etc turned off EML light came back on took it back to garage everything fine I have been driving jaguars for the last 40 years but this has got me stumped as car drives fine I have been using my garage for the last 10 years always been happy garage said everything is fine but why did my EML come back on
I do not have the circuit diagram for your car, so the following guess may be way off base.
My assumption is that the relay has +ve applied when the ignition is on and the ECU then controls the ground/earth circuit. If it checks for voltage before grounding the circuit, and there is no voltage, due to a short between relay and ECU, it will think the pump is stuck on.
Check the relay ground wire to ECU - Ohmmeter on ground at engine or other known ground and other probe on relay -ve wire to ECU. The resistance should be almost infinite.
Paulie710
09-28-2015 04:49 PM
morethansamson
07-02-2010 04:49 PM
