Code P0171
Code P0171
Gooday, I'm oats from Botswana owning an x350 jaguar v6 and my problem here is performance..I diagonised the cat and I'm getting code P0171 and I'm not sure if it's the fuel filter,flow plugs or something else...it does take off sometimes it does and when it reaches a certain stage it doesn't and the refs will be fluctuating..what might be the cause
Code received
Side view
Xj6 x350
vin
Code received
Side view
Xj6 x350
vin
Its not very easy to read the fault codes on your first picture.
Would be nice if you could type them in here. I see a fault code regarding cam postion sensor and this could typically cause the engine to go into limp mode. Then it will be low an performance and the idle will fluctuate
p.s I like your rims, what kind of brand and model is that?
