Code P1367
All of the coils and plugs were replaced about 2 months ago. Everything was perfect and this occurred all in 1 twenty minute trip. These codes all happened at once p0300(multiple cyl. misfire) p0301( cyl. 1 misfire) p0304( cyl misfire 4) p0306(cyl misfire6) p0307(cyl misfire7) p1313(misfire catalyst damage bank 1) p1314(catalyst damage bank 2) p1316(misfire rate above limit) p0351( ignition coil a primary/secondary circuit) p0354 ( ignition coil d primary/secondary circuit) p0356( ignition coil f primary/secondary circuit) p0357( ignition coil g primary/secondary circuit) and p1367 ignition monitor (bank a) ignition system failure group 1. I thought by other posts that the p1367 ignition monitor (bank A) ignition system failure group 1 was located as separate item or in the ecm as a capacitor. This looks like a trail leading back to a central ignition control for p1367 ignition monitor. I don't have any experience with this problem so any enlightenment is greatly appreciated.
Which plugs and coils were fitted?
Pinpoint tests for p1367 here:
http://www.jagrepair.com/images/Auto...ain%20cont.pdf
xjrsteve
11-26-2012 12:50 AM
