Code p2096 2005 xj8
P2096 indicates bank 1 is too lean as detected by the post-cat Heated O2 sensor. Bank 1, not cylinder 1. You'll have to do some diagnostic work to determine if the upstream AFR sensor is reporting correctly, of if the issue is only with the H02 sensor. Could be caused by an exhaust leak in the cat (after the AFR sensor) or a bad H02 sensor.
GoobeGustafson
06-20-2017 11:58 PM
TsJaguar
10-06-2015 01:50 AM
