code reader
Received 13,088 Likes
At the link below you can download the full version of the Jaguar X350 DTC Summaries manual that includes not only the common Powertrain (P) codes, but also the proprietary Jaguar Body (B), Chassis (C), and Network (U) codes:
https://www.google.com/url?sa=t&rct=...03388427,d.cWw
Most generic OBDII can read most or all of the P codes, but to read the B, C and U codes requires a scanner or system capable of reading proprietary Jaguar Diagnostic Trouble Codes (DTCs). You might check with any independent mechanic shops in your area that work on European vehicles to see if they have a system such as AutoEnginuity with the additional Jaguar extensions.
Cheers,
Don
captbob73
04-25-2016 08:25 AM
