Codes 0101, 0102, 0405, 0445, 0447 and 1000
My significant other brushed the brick wall at our driveway and clipped the right front fender with our 2004 XJ8. The body shop is done and it looks great but it is now throwing codes 0101, 0102, 0405, 0445, 0447 and 1000. It also shows restricted performance on the info panel and the check engine light is on. The battery had been sluggish so I replaced it and let the car sit without power for half an hour. The new battery is now connected and I am still getting the same codes. (I erased the first set of codes with a Actron OBD-II scanner). Where should I be looking for problems that would produce these codes?
Welcome to the forum califjag,
I've moved your question from General Tech Help to X350 forum. Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Hi califjag,
Welcome to the forum! Sorry to hear about the damage to your Jag. The codes you have read should each be preceded by a letter, such as P, C, B or U. These tell us whether the codes are related to the Powertrain, Chassis, etc. We can guess what those letters may be, but that may waste your time and ours. If your scanner can read those letters, you can look up each code in the X350 service manuals, which are available in the download section of this forum. Use the Find function of Adobe Reader to search for each code. Hold Cntrl or Cmd plus the letter F and the search window will appear. Type one of the diagnostic codes and press Enter. All the pages will be searched until the code is found. If the code is not found in that section of the manual, try the other sections until you find the code. Make a note of the information given for each code.
That information will help members of the forum to give you appropriate advice.
Cheers,
Don
philwarner
25
06-26-2021 05:43 AM
KarimPA
09-27-2015 08:46 AM
Eurocharged
09-22-2015 02:17 PM
