Coil spring conversion : Bypass module
Check the voltages on the wires. In my car, the "always-hot" line was never hot, even though the fuse was good, and I never found the break in the circuit; I just jumpered it to the other Line that was hot with key on. That discovery was made when i was still t/s the air suspension, because the scanner said the module wasn't there. Well, it had no power!
After giving up on the air and installing the Arnotts, I had to leave that jumper in place to power the bypass module, even though the connector is unplugged from the air suspension module, the bypass expects to see the voltages on those lines.
motorcarman (07-11-2021)
philturner11
08-11-2021 07:02 PM
