Coil Spring Conversion - Dashboard Warning Light?
All,
Quick question for the group on replacing air springs with coil springs. I assumed a fault bypass was available for all X350 & X358 models, but the Arnott website states "Instructions to bypass 04-06 Dashboard Warning Light" are included. I called their sales & tech support to verify the bypass was only available for 2004 - 2006 model years, which they confirmed and said there was no bypass available for 2007 to 2009 due to a change made in the vehicle.
Is there any other solution available to eliminate the dashboard warning light on 2007 - 2009 X350 & X358's after the air-to-coil spring conversion is performed?
All,
The later cars 2007 to 2009 did not have air ride suspension on the front only on the rear. The front were spring over coils. This was done I beleive to eliminate the problem being experienced by some owners on the earlier model cars with the "front" air coils.
