Completely baffled, more and more codes...ECM issue?
From my last thread , I thought I'd clean out the throttle body to start and see what would change...I no longer get "Engine Systems Error", but now I'm getting a misfire causing a very rough idle. And more codes for the throttle and pedals (?). There's nothing wrong with the battery and I doubt there's anything wrong with the throttle systems either...in any case, that wouldn't case a misfire. Anyone have any clue what's going on?
============1==============
U0401(64)
Raw code: C40164
ECU: 768[Archive (inactive)]
Status: Confirmed, Test failed since last DTC clear
Invalid data received - engine control module (ECM)
============2==============
U0401(92)
Raw code: C40192
============3==============
P0222(00)
Raw code: 022200
ECU: Engine control unit
Status: Pending, Test failed since last DTC clear, Test not completed during this operation cycle
Throttle position (TP) sensor B/accelerator pedal position (APP) sensor B - low input
============4==============
P0122(00)
Raw code: 012200
Throttle position (TP) switch A/accelerator pedal position (APP) switch A - low input
============5==============
P061A(29)
Raw code: 061A29
ECU: Engine control unit[Archive (inactive)]
Status: Test failed since last DTC clear, Test not completed during this operation cycle
Engine control module (ECM), engine torque - performance problem
============6==============
P061A(64)
Raw code: 061A64
============7==============
P050B(84)
Raw code: 050B84
Ignition timing, cold start - performance problem
============8==============
P0316(00)
Raw code: 031600
Misfire detected during start-up - first 1000 revolutions
============9==============
P0307(00)
Raw code: 030700
Cylinder 7 - misfire detected
============10==============
P2105(00)
Raw code: 210500
Status: Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle
Throttle actuator control (TAC) system - forced engine shut down mode
============11==============
P0122
Raw code: 0122
Status: Pending
============12==============
P0222
Raw code: 0222
Status: Pending
============13==============
P0316
Raw code: 0316
Status: Pending
============14==============
P0307
Raw code: 0307
Status: Pending
============15==============
P2105
Raw code: 2105
Status: Confirmed
U0401(64)
Raw code: C40164
U0401(92)
Raw code: C40192
P0222(00)
Raw code: 022200
P0122(00)
Raw code: 012200
P061A(29)
Raw code: 061A29
P061A(64)
Raw code: 061A64
P050B(84)
Raw code: 050B84
P0316(00)
Raw code: 031600
P0307(00)
Raw code: 030700
P2105(00)
Raw code: 210500
P0122
Raw code: 0122
Status: Pending
P0222
Raw code: 0222
Status: Pending
P0316
Raw code: 0316
Status: Pending
P0307
Raw code: 0307
Status: Pending
P2105
Raw code: 2105
Status: Confirmed
a4500435
04-16-2023 09:47 PM
sws805
01-24-2013 10:58 AM
