confusing part numbers of door lock actuator
My front left (driver door) latch lock actuator is broken. I disassembled it and it looks like some mechanical defect is inside, which I cannot repair.
My original part is labeled 2W93-219A45-AG.
Looking around, I find parts like 2W93-219A45-BM, which also seemed to be mounted on the same place in same cars.
Is there more then one partnumber which would fit ? How to get all matching numbers ?
Hi
I have bought used door actuators in the past and as long as it specifies, for example, front LHD driver's door
and the donor car was around the same age as yours it will fit.
what are the symptoms of the fault?
Is it just completely dead?
I find that the micro switches fail and I replace them.
My problem is, that some parts don't show whether there are two lever (like needed for driver door) or just one.
Finding exact the same partno is very tricky.
My micro switch is also dead.
But I suspect, there is more:
I moved the while wheel in both directions while I simulated a locked door.
It didn't open.
I had to pull the lever to get it opened.
Is there a more tricky sequence of the whiite wheel or should it open by moving from end to end ?
It didn't open.
